Arlo base station range question
Is it possible or necessary to boost the boradcast range of my base station? Two of my three cameras indicate a strong signal. The third camera indicates a poor signal - instead of three or four arcs, it shows a red dot...
You can't boost he base range. You can either reposition the base to be more centralized or use a second base for that problem camera to sync to.
