  • 7 Replies
  • 2775 Views
Swiftynutz
My base station goes off line at least once a week. I have to reset it everytime it does this.
Swiftynutz
I would like to give a update.
I purchased a arlo pro 2 base station, and have not had a issue since. Thank you all
7 REPLIES 7
What status are you seeing on the LEDs when it does this?  https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
How old is the base?
Swiftynutz
The base station is 2-3 years old. I’ll look at the lights next time. Because I’m not sure. Thank you!
It's possible that it is failing.  Though hopefully not.
Swiftynutz
I had to buy a wifi plug, so I can reset it when I’m not home.
ZDurkee
I have the same issue, what brand of WiFi plug did you buy ?
Thank you!
Swiftynutz
It’s a Kasa wifi plug.
Swiftynutz
