My base station goes off line at least once a week. I have to reset it everytime it does this.
Message 1 of 8
2,678
I would like to give a update.
I purchased a arlo pro 2 base station, and have not had a issue since. Thank you all
Message 8 of 8
2,412
7 REPLIES 7
What status are you seeing on the LEDs when it does this? https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
How old is the base?
Message 2 of 8
2,668
The base station is 2-3 years old. I’ll look at the lights next time. Because I’m not sure. Thank you!
Message 3 of 8
2,665
It's possible that it is failing. Though hopefully not.
Message 4 of 8
2,663
I had to buy a wifi plug, so I can reset it when I’m not home.
Message 5 of 8
2,661
I have the same issue, what brand of WiFi plug did you buy ?
Thank you!
Message 6 of 8
2,631
It’s a Kasa wifi plug.
Message 7 of 8
2,556
Message 8 of 8
2,413
