Arlo base station network adapter specs
  • 4 Replies
  • 8332 Views
Paul_FCCL
Prodigy
Prodigy
What are the Arlo Base Station network specs?
Thanks,
Paul
Both bases use 10/100Mbs connections, not gigabit (no need). I have mine connected to a gigabit router and the LED is amber, indication 100Mbs.
Adewale
Luminary
Luminary
its a 2.4GHz base station. it connects wirelessly only to the Arlo wireless cameras and connects via RJ45 to your router
Paul_FCCL
Prodigy
Prodigy
Actually I was referring to the ethernet adapter capacity/speed, 10/100 Mbt/s or the newer 1000 Mbit/s?
Would like to know that in helping with my decision to relocate router and base station connected via powerline adapter/extender.
Many adapter make and models out there, all claiming extremely high speeds.....of course the base station own ethernet adapter speed will limit the actual transfer speed.
Also wondering about the new Arlo Pro base station and how it compares to the older one in that context.
Thanks,
Paul
Paul_FCCL
Prodigy
Prodigy
You're right, I thought so.......the current speed isn't going to change either way. Even connecting base station to a gigabit adapter/extender isn't going to make a difference in the end.
So I'll just relocate router and keep base station where it is now (right in the middle distances from cameras), connected to 300-500Mbs extender and that should work fine.
Thanks for your input.
Paul
