is it possible for some one to create an account by using the numbers on the bottom of the base station even if I already have an account setup? I'm afraid i have been hacked because someone has been unplugging the inernet.
The number is prob the serial numbar of the base... the base serial is locked into your account so I woud so , prob not likely.
Use a good password and you shouldn't have a problem.
If some one is unhooking you internet, maybe a PRO unit or a Q+ with local record options would be better suited
thanks for the info and I will check into your suggestion:)
