  • 6 Replies
  • 6892 Views
  • 3 Likes
jimsoltis
Can the Arlo base station be connected to a wireless MiFi? and if so, How?
brh
@jimsoltis
Have you looked into wifi range extenders? I purchased one from Netgear with a ethernet plug to connect a second Arlo base station to for under $60.
Brian
6 REPLIES 6
brh
@jimsoltis
The Arlo base has to connect physically to your router throught the provided ethernet cable, so the answer is no if it does not have an ethernet port.
Brian
jimsoltis
Is there a recommended router that could connect wirelessly to my MiFi that then could be connected physically with the cable to the port on the base station?
brh
@jimsoltis
Brian
jimsoltis
Brian, thank you for the reply. Was the N600 Netgear the one you used?
@brhwrote:
@jimsoltis
Brian
brh
@jimsoltis
This is the one I purchased from Amazon:
NETGEAR AC750 WiFi Range Extender (EX3700-100NAS)
Brian
Frankly, virtually any extender with an Ethernet port can be used.
