Arlo app keeps glitching and signing me out,
  • 1 Reply
  • 1531 Views
Hamperella
The app keeps glitching and signing me out, I forgot the email I use to sign into the app and don't have access to that email any longer, how can I change my email/sign in info so I can access my cameras?
That's a bit contradictory.  But you could try PMing @JamesC or @ShayneS , and see if they can give you the email address.  Not sure if they can - it might violate Arlo's privacy policy.  But worth a try.
Send a PM using the envelope icon on the top right of the forum page.
Are you able to log in at all?  If you are, then it's probably simplest for you to remove the cameras and base from the account.  Then create a new one, using your current email.
What do you mean by "glitching"?
The usual process is here: https://kb.arlo.com/4118/How-can-I-change-my-Arlo-email-address
But you do need to be able to log into the app to use it.
