So one of my cameras has notified me of motion 2 times yet the icon on my phone (iOS) says 142 notifications on the icon. Really? This has been going on for a while now. And yes I have the latest version. Should it not say 2 instead of 142.
I find it really interesting that Arlo kept the old app available, renaming it Arlo Legacy, instead of just updating the app in place. It's almost as if they knew the risk of problems was significant...
Still using same version as noted above from 8/30
Both on the app logo & on the library icon in the app.
The alert notification count in the Arlo iOS app [version 2.8 (909)] keeps increasing endlessly.
Previously, after one or more alerts appear, I would lauch the app and select Library. After displaying the alert videos, the alert count would disappear and new alerts would start over with number 1.
Now, after I check the alerts buy selecting Library, the alert count still disappears, but new alerts now show a cumlative total.
For example, if I have 5 alerts, I'd check them and the alert notification goes away. If I then get 2 new alerts, the notification count now shows 7 rather than 2.
The count is now at 106 and shows no sign of stopping.
Surely this isn't the expected behavior.
I've tried deleting a re-installing the app, but the count keeps climbing.
Has anyone else seen this? Any idea how to fix?
Thanks.
Ever since the app migration, I've noticed that I get notifications in the app that an event has recorded.
What used to happen is you would view the library, the count badge would disappear and reset to 0.
Now, since the migration, when you view the library, the count badge disappears, but it does NOT reset to 0.
So now, it just adds one to the event count and keeps on adding.
e.g. Monday, I get 23 notifications. Look at the library, the badge disappears, but when I get a new notification, the badge shows 24 notifications, and not 1.
The counter is not resetting when the video is viewed, so over time, after a few months, that badge is going to be showing in the 1,000's of notifications, with no way to reset it.
Anyone else experiencing this?
Arlo Mobile app version 2.9 is now available for iOS supporting iOS13 and resolving the issue with badge notification not resetting. Please make sure you have the latest version of the mobile app downloaded from the app store.
For more information take a look at the release notes and knowledge base articles below:
Yes, after installing v2.9 today, the badge counter is now working correctly.
Thank you!
The updated app works as expected for me. I'm still curious as to why it's a new app, not an update to the "legacy" app. But most likely the answer involves obscure details ...
Arlo, hope your “listening” and can check this new issue out and fix it.
@Linusl wrote:
Most likely because the app account was owned by netgear. So arlo setup tjeir own account and added tje app there.
Exactly. Arlo explained that in their announcments.
Where can I download 2.9 version app ?
Where can I download the new app? I only found the one date 9/17. Thanks
Looked like it worked for a few hours but now I see 1455 badges on my arlo icon. Im sharing access to my wife and she has not yet updated to the latest vr for ios13. But from my point of view having the lates vr the problem is not fixed.
Our development team is still looking into this issue if you are still experiencing problems with the badge notification still showing incorrectly. We will be sure to update the community once we hear more information or update. We appreciate your patience and understanding and apologize for the inconvenience.
