So one of my cameras has notified me of motion 2 times yet the icon on my phone (iOS) says 142 notifications on the icon. Really? This has been going on for a while now. And yes I have the latest version. Should it not say 2 instead of 142.
Downloaded the new Arlo app. Works fine except with alerts. They are “cumulative”. That is, if I get an alert, my app icon has the number 1 on it. Once I view it, the alert goes away. But if there is one more alert, the number on my icon is 2. And so on. I just got an alert and my notification says I have 28 alerts. Again, it seems to be accumulating all old alerts instead of just telling you how many you have since you last viewed your library. Strange.
Having the same issue ! please fix asap ! I got this since more than 3 weeks !
I downloaded the new Arlo app from the app store, logged in, and deleted the Legacy App. Ever since for each push notificaiton sent to me by the device, the red badge on the app's upper right corner reports between 4 and 9 more recordings than are available. Phone support couldn't understand my issue, and I can't find a clear place to report app bugs. Again - push notifications are working correctly and recordings are working correctly - the bug is in the small red badge on my iPhone's homescreen showing way too many notifications. I've rebooted the phone, the base station, and re-installed the app - no luck. iPhone SE, iOS 12.4.1, Arlo app 2.8 (909)
I have the EXACT same issue. I'll have like three notifications in reality but he red badge on the iPhone indicates way more. PLEASE FIX!
I downloaded the new app and it appears to work fine and I do get motion notifications for all my cameras on my iPhone. The problem is that the app will report the wrong number of events. Right now it shows 106 on the app icon, but if I open the app, there is only one or two in the library. Opening the app does clear the number, but when I get another notification, the number is again an impossible number. Is it counting all the motion events in the library for all days, when it should be just showing the unviewed ones? How can we fix this? It is rather annoying.
This is driving me nuts. The sooner you can resolve the issue or update the new app the better. My notifications are in the hundreds and I cannot clear them. Yes, I have the new app, yes, I have re-booted the 'phone and yes, it seems this is affecting a lot of people.
I have the same notification issue as the previous 39 posts. This just started when you notificedme to upgrade the App for your spin off from Netgear. All was fine in the previous version. Please fix this!
Why does Arlo not fix this problem in the new app ? This issue didn’t exist in the old Arlo app. Thanks
Arlo, how on Earth are you a public company? Embarrassing ...
