Yesterday I set up the Arlo wireless cam and base station, created the account, and tested the app as well as logged on to the website to verify I could see the live view. Everything worked as it should. Today I opened the app at work to verify it would work when not home. The app will not boot, it just keeps re-booting. Both the base station and camera did a firmware update, but the app worked fine at home after that. Using a Galaxy Note 4 running Android 6.0.1.
Thanks in advance for any help.
Mark
It's been pull. Using the Play Store uninstall and then reinstall. That will get you the previous version.
there are a couple of threads on this ...bad app update... read some of the others
Thanks, uninstalling and reinstalling fixed it.
Mark
Mark
