I tried to setup an Arlo add-on camera with my Netgear Nighthawk (R7000) router. My router is firmware version V1.0.6.28_1.1.83 (latest available). I also did a factory reset of the router after updating the firmware. I initally was able to add my router to my Arlo account via the Arlo iOS app, but the camera was not adding properly. When the camera was finally showing up in the Arlo app, video was unavailable and the camera status constantly said "Busy". I went through multiple iteration of removing and re-adding my router and the camera to my Arlo account. Now, no devices show up in my Arlo account and I am unable to add any devices. Very disappointed with my Arlo experience thus far.
I had the same problem. Do you have a USB drive attached to your R7000?
Yes, I actually do have two HDD's connected to my R7000 via the USB 2.0 and 3.0 connections.
Take the HDs off. There appears to be an issue with USB devices being attached when trying to use the router for Arlo.
Vash,
We are aware of this issue and our engineers are actively working on a resolution. Thank you for bringing this to our attention. We hope to resolve this issue as soon as possible.
Make sure you disable USB within the R7000, also even when you are up & running if you re-attach your USB drive the cameras will not fuction. I have opted for a Netgear NAS bay & HD.
Have also read that the router provides a stronger signal than the base station. It may not make much of a difference for you, though, because you're well within maximum range.
Maybe were using lag to describe different things. The traditional lag noted here is for the wireless cameras to not record for at least a couple of seconds after motion is detected. I now think you're referring to the amount of time when live viewing before the video is seen on-screen. Which are you using?
Lag in regards to while looking at the video feeds from the Q vs non Q, the non Q display the movement before the Q model does.
Can't say for sure. It may be the way each camera type handles the stream since the Q is always streaming and may have a different way of processing and displaying the scene. It's also possible that the Q is using a different server with more delays in the transaction.
Just guessing here.
I suspect it's because it's processing audio as well. A simple test would be to disable audio collection and then compare.
I just purchased a brand new R7000 from Amazon that arrived yesterday. During installation it performed a firmware upgrade to the latest (it said). It is now running V1.0.5.70 and their is no Arlo in the Basic tab in Genie. How can I get the version that allows Arlo?
