Arlo and Oreo
So the mods deleted my original post. Yay censorship!
On Friday my Galaxy S7 updated to Oreo (8.0.0) and since then geofencing has been screwed up. When I am at home the app says I am away, when I am away it says I am in zone.
I noticed that over 40 of my installed apps have had updates since the Oreo update, so I am assuming thy needed to make some changes to be compatible with the new Android version.
So Netgear, how about fixing the app and not deleting my thread asking for you to fix the app. If it was because I was rude, well you only have yourselves to blame for my anger.
Fix. The. App.
(PS I saved a copy of this post. Delete it and I will just re-post)
madkiwi,
Engineering is currently investigating some issues with the geofencing feature. No recent posts submitted by you have been removed as far as I can tell. Do you recall the subject line of your post? It's possible it may have incorrectly been auto-tagged as spam, if that's the case I will see if I can find and release the post.
The subject was "Christ on a stick! Geofencing and Oreo update"
The url was https://community.netgear.com/t5/Arlo/Christ-on-a-stick-Geofencing-and-Oreo-update/td-p/1592776
