  • 5 Replies
  • 1424 Views
jsbek
I have 2 arlo pros and 3 originals.
one day out of the blue the 3 originals went offline. no internet lost, no power out.
the pros work fine.
so I do the usual:
replace batteries
reset modem, router, try to rsync
still no luck
5 REPLIES 5
ShayneS
Hi @jsbek
Just to be clear, You have already tried to open & close the battery doors on the wire free cameras?
jsbek
correct. I'm usually good with these but lost here
Have you removed one camera and resynced it as a test?
jsbek
yes
It's possible that doing a factory reset (remove all devices from Settings, My Devices and set back up as new) may be the fastest resolution. Be sure to note all settings, modes, rules and schedule to speed rebuilding.
