  • 1 Reply
  • 3274 Views
Linhclark
Arlo Wireless base station third light orange and does not sync with the camera. I reset, delete the app, resync, charge all the cameras. And still it did not work . I don’t know what to do. On my app there is no mode section. There are only devices, Library, and setting.
steve_t
Master Master
Go into your app. Remove all of the devices. Go to the devices tab. Add a device. Choose a base station. One you have claimed/added your base station, only then can you sync the cameras
