Arlo Wire-Free motion detection stopped working after heavy rain. Getting nonstop alerts.
2/3 Arlo Wirefree first model cameras went haywire after heavy rain. I started getting nonstop alerts from one. The infrared stopped working on 2. I took one down, dried it off and took the batteries out and removed from app/base station. When I put the batteries back in I noticed some water coming out from around the motion sensor. I was able to get the infrared/night vision to work again. And live feed works fine, but it will not detect motion. Also, the battery power dropped suddenly from 60% to 20% on both cameras.
Check the seal around camera door for proper placement....
If less than a year old, you may want to file for warranty via Arlo support.
The seal around the battery door is the one in question. There are other seals (lens, face plate, etc.) but you can't do anything with them unlike the battery door one. These cameras are weather-resistant (I wouldn't call anything -PROOF) when the seals are in place, undamaged and properly utilized.
And the IR LEDs should never go off in bright light. If you mean the motion detection PIR sensor, anything is possible. If water got into the camera, it may be that it's not dried out completely or there's permanent damage to the electronics.
You never mentioned the grey screen at daytime in original post. they were giving advised since you said it had water comming out and led lights. Short of contacting support or replacement if under warranty like suggested not sure that anyone can help here.
