Arlo Wire-Free camera and works only partly
Can login only home network and internet explorer,crome doesnt work. When login with explorer and try verify email adress it say email send,nothing happens.Try reinstall and same thing.what try next or is it best take system back to store?
Heikki,
Do you get an error message when trying to use Chrome? If you are able to access using internet explorer that means the system is working. If you are not receiving the verification e-mail after the system setup consider contacting your ISP to ensure that Arlo is not blacklisted. Let us know!
