							Arlo VMB3500 how to keep my computer from shutting down?
How do i keep my computer from shutting down i want to be able to look at computer and see the camera's monitoring
I assume you don't mean that the computer is turning off but that the web interface stops and wants you to log back in. This is due to the lack of activity on your part to keep the login from timing out - a security feature. It's possible that you could walk away and someone else could sit down and delete cameras or change settings unbeknownst to you.
Also, the cameras will time out of live viewing after 30 minutes since the cameras are battery-operated and not designed to stay awake.
1  -
1  -
1  -
