I have a kiindle and when loging into arlo.netgear.com, it assumes that I have a mobil device and say I need an app. Problem is that there is no app for a kindle.
How can I get around this and use the browser for access?
You can not... the Kindle is an android base system with a "shell" on it. So it does work and thinks it's android.
At one time there was a Kindle app, but with the updates along the way it was dropped about 7 -9 months ago
I don't think you'll be able to use the Kindle as there is no flash , tho there are many other browsers you could try...let us know how you make out.
But looking for a solution to fool the browser into thinking that the kindle is not a mobile device.
The kindle silk browser if a chrome browser modified for the kindle.
This could be a netgear problem, because it identifies my kindle as a mobile device and only gives me the option of using an app, for which non exist for the kindle.
