Have found that the location facility is quite handy BUT there is at least one annoying oroblem, almost certaintly two.
Problem 1.
Can change location fairly easily if an essential camera 2nd generation is considered but if 1st generation considered or any older product such as wireless doorbell or chime there appears to be no way to change location without uninstalling from account and reinstalling. Needs to be sorted if I am correct.
Problem 2
I have a professional plan and one would hope that this would cover multiple locations. So far I have found no way that this is the case. I have 3 locations and the shortest distance between any of the locations is 600 miles. Effectively makes the professional plan useless. Not impressed. Just hope I am wrong.
Unfortunately you need a subscription for each location.
