All working fine until I had to change my password. As soon as I did that, it set me up like a new customer. Said I need to set up base and all cameras so I cannot see motion video being recorded. My location is remote (5 hour drive) so not easy to just go to site and work on. Why would a password reset change any of my settings, camera sync or access to what I had before? Frustrating.
did you verify the email was exact...
Yes, thank you. Makes sense but that is not the cause. Same email, just password change.....
David414,
How did you perform the password change? A simple password change does only that, this would not result in a new account being created or a reset of any system settings.
Thanks James. That is why I am puzzled. I could not get into the account, requested a password change via the link at sign-in. It sent me to make the change, which I did. I went to sign in and it did with the new password but everything was gone. No cameras linked, etc. Put me in the "set up a camera" phase. Agree completely that nothing should have changed but it did and I do not know why and cannot "go back".
David414,
Does anyone else have access to the account? Are you noticing any odd behavior now that you've changed your password?
