Arlo Original Wire Free camera Goes Offline
My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
Can you kindly provide your camera firmware version and base system firmware version? Which base VMBxxx do you have?
I am having the same issue, the camera I got with the base kit is offline and I get it back up and then it tends to go offline. I purchased another arlo cam on amazon and it is working just fine so far! Why is this a problem, I am getting very upset having to keep going out and taking camera down and bringing it into the house base station and having to set it back up again! Come on you are a better company than this! Lets get a firmware update or something to correct this issue!
Here is the screenshot of the issue! One Is Working The Other Is Not?
Tried Arlo Support, No resolution just the same answer: new batteries, re-boot, unplug and the distance from base station is approx. 20 ft. but the other cameras are working. Purchased the 4 year warranty but can not use due to still within 1 year warranty with manufacture availble (Dec,2018) so can't be used. Someone just give me a resolution and I won't bother anyone just want it to work!
I have 5 cameras, and one of them (the most important set up to monitor the front entrance) is Off Line for 2 days now. All other 4 is ok. I am on holiday and would like to know 1. why? and 2. how to fix it remotely 3. how to fix it at all Thanks in advance.
Currently one of the camera is off line and I can’t reconnect it back to it second base.
Still the same problem after a few days
Now what???
Oh reset every other day
LOL
I have 2 systems each of 3 cameras, I have lost 4 cameras to the replace battery prompt, none of the 4 cameras have recovered with new batteries, I have also a base station that will stay up for a couple of hours then drop the config, none of the arlo help guides work. this is most likely due to this equipment is the worst on the market, not fit for purpose poorly made, full of bugs, and how arlo can promote this junk is beyond reason.
Other people have said do not spend your money on this kit and run a mile away, I endorse those statements, I had years of trouble cameras with Y CAM
@RoniV With all due respect a lot of us here know how to select wireless channels etc. Glad that was your problem but please don't pollute the thread with bad advice. There are bugs in the Arlo firmware we need to get fixed and that's where the focus needs to stay.
Is there any solution to free up a congested 2.4 network? My cameras go offline all the time also and it is so annoying!
If you've logged into your router and checked the DHCP Lease (Devices List) to confirm the router runs out of internal DHCP addresses to hand out to devices, you can change the DHCP range to allow more devices to connect. It's usually found under Basic Network settings (varies by router).
If the router's DHCP table isn't full then you likely have other instability issues going on with your WiFi. Also you may have a poor performing router, it's tough to tell without more info.
Good day
I have 4 cameras and each one has been consistently going offline for the last 9 months. They seem to work for 3 days or so and then one or several go off. Even after I open and close the battery compartment they go back on about half the time. I'm getting tired of rebooting, resetting and recharging. Unless Arlo fixes this issue, they are looking at a potential class action suit.
It just says base station offline check if connected to internet
I have had the first two lights on for some time. I have been tring to sync the cameras. Well, I finally got them sync back in, now the internet as went off!!!!!!! I have went through All of the troubleshooters. This has really been a nightmare!! I need the system working!!! We don't live in the best neighborhood. That's why we spent alot of money on this system!!! PLZ HELP.
Well, thought it was fixed about an hour ago but now cameras are showing "getting status" again. They have been getting status for about 3 months now. Worked for about 15 minutes today. What is wrong. How come it all can't work together like it did when we fast bought this mess?????? Just so disappointing!!!!!!
and again. Cameras off line again after working for two or three weeks. I don't have time to sit on the phone for a several hours waiting and finally get to talk to someone in foreign tong who is going to pile ton of computer terminology on me that i can't understand. Sick of this arlo. Arlo. Arlo. Do something arlo support. Keep in mind that there is nothing on the box saying that you must have MS in computers in order to use that arlo nonsense. And very expensive and nonsense.
I have the same base station and camera with the same firmware as everyone. Mine started to go offline end of June as well. Tech support is of NO help. Garbage. Arlo is horrible.
