Got the system set up without much problem. Getting it out of the box was the hardest part.
Now I am getting into the finer parts.
I have 2 cameras set up, one in the house, and one pointed to the car outside.
I am trying to set up for Geofencing on the house camera and use the schedule for the car.
I can't seem to be able to use both.
When I click on Mode, I don't get a list of the 2 cameras but see the Base displayed. This is what I named the Base station at setup.
Did I get it set up wrong right from the gitgo?
Please show what the steps are to do this.
Thansk
Please explain "geozone"?
How do I undo the default?
Will check the FAQ's
73
Dave K1OXD
I always forget the name and call geofencing by the name geozone...
Your add custom modes to split up the Default ARMED ( all on )cameras into groups , like inside/outside, front/back, etc
feel free to ask
TU
Tom
You can ONLY have ONE active MODE running at a time.
To start, take a looks at the FAQs, about custom modes ...you need to split the cameras apart due to the fact as default you only have all on or all off
( and you can schedule a mode and then use it in geozone )
Thanks for the reply.
73
Dave K1OXD
73
Dave K1OXD
feel free to ask
TU
Tom
Tom,
Thanks for the great help! Appreciated the links.
I guess I just just have to change the mode in the evening when I only want only the outside camera on.
Dave
Why not use the schedule so the modes change automatically?
I am under the impression that the Modes are mutually exclusive.
When the Geofence is checked, isn't the Schedule disabled? It only allows me to check one?
Appreciate more information.
Thanks,
Dave
