I just bought a 2 camera systwm from costco. Set up was fairly easy. I placed the cameras pointed at my mailbox but the motion sensors do not detect anything even when sensitivity is set to 100% What is the range. The web site is lacking for findaing any way to get some sort of live support or even an 800 number. Considering just returning it because I need the motion sensors to work because I dont want to watch the video all day to see what is going on t home..Any suggestions?
People detection is about 20 feet, with motion across the FOV. It will vary according to the exact camera type, motion, size of the object, etc.
As just in case... the motion detect does not work thru windows at all... glass blocks the IR needed for the sensor to work
Will looking into direct sun impact motion detection. Camera is pointed to the west and is not detecting motion in afternoon.
Usually the issue is too much motion detection due to reflected IR from the sun. It could be that the sun's IR is masking other objects. Have you tested it by walking in front of the camera to try to trigger it?
Yes, we have walked in front of it and it did not detect any motion. I have tried changing the sensitivity also with no change.
I was in Mode and not in Motion Detection. I have readjusted the camera, increased the sensitivity and it seems to be working better. I also had to restart the base station. What I do see is a delay in motion detection and recording start. What is the typical delay. Prior to changing the sensitivity I was able to walk through the FOV and it didn't start the recording until I was almost out of the FOV.
Sometimes if vehicles go fast enough we will not see anything in the image. Sensitivity set to 95%. Considering moving camera farther away from brick and pointing more towards the door. Thoughts?
