I recently purchased the Netgear x46 r7800 router hoping that i could sync my arlo hd cameras directly to the router without the need of the Arlo base station. I read the netgear support/message boards and it appears that it was a feature on the R7000 model (integrated with the router software) on some firmware versions.
Can i set this up with my X4S R7800 router?>
Thank you! I really which they develop a new firmware version that wil support that feature. Hope that happens in the future, i believe that it will be an incentive to purchase netgear routers vs. other brands. Im still happy with my router purchase, but i would definitely be more ecstatic if it had this feature.
Even the R7000 with the latest firmware doesn't connect directly to Arlo wireless cams. You'll need a base station
No... the 7000 had SW in the early stages of Arlo ( back in 2015 and early 2016 ) but the router dropped the SW as they were having issues with it operating.
There is no router at this time that supports the Arlo cameras directly
