Arlo Camera Not Recording
My Arlo camera system is not recording to the library. I have contacted ARLO support to no avail. They tell me the server is down. I depend on this sytem to watch over a home, and it is useless if it doesn't record to a saved library. I even upgraded my plan thinking that it was my error for not having the paid plans. Still no deal. I removed the base station and reinstalled the cameras as several users have suggested and it still doesn't show the recordings. I created a test mode and only assigned one camera and tried that. Still no luck. Any thoughts?
The server isn't down as far as I know and hasn't been for a long time. Are you sure you talked to Arlo support?
Can you live view and manually record? Are the running men or new motion icon (ball and 3 lines) for each camera in the Devices tab black or gray? Gray means disarmed. What country are you in?
Thanks for the prompt reply.
I can manually record and it will upload to the library. So this is a testament that the server is working right?.
However, motion activated does not upload to the server. and Live streaming says a message:
"The media server has intentionally stopped streaming". this message also appears when a motion activation has occurred.
Yes, any utility at all means the servers are working.
I've seen the "intentional" message a couple of times. It's always been at the end of my recording and the recording has been in the library. When in the process of recording do you see this? Is there a chance that you have a filter set in the library (the funnel icon is filled in, not empty)?
Is it for all cams?
I have 2 cams, Pro 2s that will not record to the library or give me alerts. My pro 1's and one other Pro 2 will tho. very stranger
I moved the base station away from any interference but this shouldn't matter as the manual records go to the cloud.
I'm at a loss. I have a 4 camera system that is a dud. I've contacted customer service several times. All calls go to India. Last call was for over an hour and they continue to repeat the same steps over and over.
I am having the exact same issue for a few weeks now. I was under the assumption that the system was changing over. I contacted tech support and they suggested I reset the system, but nothing. I can activate the camera and see a live feed... but when motion is detected, I get the notifcation, but nothing is recorded. It is stuck on the first day of the month. Last month is was stuck on Jan. 1 and now Feb. 1. I have had the system for a few years with the basic 7 day rolling cloud storage plan.
Is there a chance that somehow your modes/rules for the cameras have "Do Nothing" selected and have notifications enabled?
Okay...I reset my base station again this time using a paperclip inserted into the reset as well as unplugging it. I also got rid of my cable provided router/modem and purchased a high speed netgear nighthawk router. Everything works now.
No, nothing changed. I had been recording videos perfectly until recently. I have had 5 cameras since 2015 and have the system perfected, which is why it is annoying that all of a sudden it stopped. If I go on the browser and manually record something, it will work - but nothing automatic based on motion. I manually recorded something today as a test. The exterminator came out today after this test and I received notifications, but no video was recorded. I attached a screenshot of the library.
Thanks for the info. I will probably have to do that as well... shouldn't have to do that, though.
I am having the same issues with one of my two cameras. It just suddenly happened out of the blue. Nothing works to get this camera to automatically record. Manual recordings work fine, but the camera does not send notifications when there is activity in front of it.
Hi @Mattocs
What troubleshooting steps have you performed so far? I do not want to suggest anything you have previously performed.
I would suggest contacting support and let them know you have been through all troubleshooting steps possible.
I seem to be having the same issue as you with my Arlo Pro 2 camera starting a day ago ( was fine for about 8 months prior). Did you ever get this addressed?
I have 2 cameras and one works fine, but the other stopped detecting/recording video. I tested out motion detection manually and it works, can record video manually. I removed the battery, removed the camera from the app, added battery back in and re-synced, but still it won't detect motion & record. Tried this multiple times.
I talked to customer support this morning and they suspect a faulty camera and my camera is in warranty. After I get home they wanted to try a few more experiments before dispatching me a new camera.
I did a reboot of the entire system and that seemed to work. But, right now I have one camera that won't cooperate. I also have some unreliability when it comes to the geofencing... and the quality on the cloud recordings seems to be very pixelated now. I have had the system since late 2015 and it has me thinking about an alternative rather than spending more money to upgrade everything.
@DDarling007 , I rebooted everything several times, but no improvement. Only happening on one camera.
Hi. My recordings of motion works fine, but, as soon as I add to activate the siren, the recordings are not saved to the library. If you look at the image attached, as soon as I choose 'Turn Alarm On', my recordings does not go to the library. Any advice maybe? Thanks.
Hi @Shrick
I have the same issue. It has been like this for a few weeks now. I am convinced this was caused by a firmware update pushed out by netgear. My cameras repond during motion detection test, I can watch live and I can manually record; but motion detection and auto record will not work on one of my cameras. I’ve tried resetting everything. This works for a time and then it fails again after a few days. I am really annoyed because I live alone and travel a lot with work. I need these cameras to watch over my house. So many people have the same issue lately, it is clearly a central issue with netgear and yet they are doing nothing to address it.
