arlo system has worked fine for about a year, but recently we had a camera go dead. We have changed the batteries, cancelled the camera from the system and resync'd it with no success. What do you recommend as the next step?
open battery door
go to settings and for that camera use remove device
reboot base via the power button, let reboot fully
CClose battery door
resync camera as if new
if it still fails, contact Netgear support
open battery door
CClose battery door
That did the trick, thanks
