Arlo Broken in Last Update?
My Arlo cameras will not reset with the "live" label on the Arlo app with iPhone. Please fix. It worked fine before the last update. Even closing out the app does not reset the application.
9 REPLIES 9
Lineman101,
Consider rebooting your base station (using the on-off button). Allow the base station to come back online with a solid green power and internet LED and try again. Do you still see the same behavior?
I would agree, iPhone app seems broken, still sending alerts once I turned it on via the web. But the app just does not want to connect. Even updated iOS. No joy....
David567,
What do you mean when you say the app does not want to connect. Are you seeing an error message when trying to sign in?
Send to log in ok, but can't check device status or change status arm / disarm etc. Works fin though the web. Tried reinstalling app no joy
Try rebooting the phone. Is there a difference between using cell service and WiFi?
Done that a couple of times, wifi and cell exactly the same. But the web interface works so it must be the app. Just frustrating, it was working well.
David567,
What version of the mobile app are you using? Check the app store and make sure you have the most recent version.
Did all that, now started working again, I guess a server side issue. Very frustrating, otherwise a good product.
