I have 2 arlo with same configuration but on the indoor camera in the last 2 months the battery drains very quickly, in about 10 days.
This Arlo have the problem: Hardware H11 Firmware 1.2.21616
This Arlo don't have the problem: Hardware H7 Firmware 1.2.21616
I used the same batteries in the two cameras. I also tried to switch
Swap cameras around to see if it's the camera or the location.
Done, it is note the location
giovesoft,
Have you tried contacting customer support regarding this issue? I have attached the link below for you.
Problem solved, cam replaced by amazon
