Arlo Batteries lasts 2-3 days. Haven't changed location.
We recently found out that our Arlo camera batteries die extremely fast... Have had 5 cameras connected to base stations, and batteries usually last about 6 month. Haven't move camera locations at all. Now, a completely new set of camera only last 2-3 days. Have tried re-setting the base. Didn't work... Any suggestions?
That tends to imply that something near the base is interfering with the signal. Anything that uses a 2.4GHz signal (not just WiFi) can cause this. Check to see if something has been moved or placed near the base. You can try moving the base, too.
Camera and base ping each other... if a bad signal to base, the camera tries more often and it can use more power doing so
I have neither moved Arlo base location, nor moved anything close to base station.
I suspect my system has outdated firmware... but not sure how to verify...
Compare what is installed in your devices' setting with what's posted in the Release Notes section here.
