- I purchased my Arlo on 2 separate occasions and I have ended up with a base station WMB3000 and a WMB3500. I currently have 5 cameras working off the WMB3000 and although the Wi-Fi signal is weak on the cameras furthest away from the base station, everything works as it should.
- Would there any benefit to replacing the WMB3000 with the WMB3500? Is it a newer and stronger unit?
Newer but not stronger unless one has a hardware problem.
