We had some internet issues a few days ago, and since rebooting our router etc our base station is showing as Offline in the app.
The cameras are synched, have been re-synched, and the correct LED's are showing up on the base station, but for some reason, the system is offline.
Not sure what to try next, would appreciate any help!
We have three Arlo cams, all showing offline currently. Oh, and our internet has been up and running for days now with no down time.
turn all off and try and bring them back up in this order ...modemm - router - arlo base
This same thing is happening to me and the fix does not work, please help
Reset the base station to factory settings.
Have you remove all cameras first? Unplug from wall? Plug back in and see if you can see it in your router settings?
I too am having the same issue...did a factory reset, I have internet and power LED both green, and cameras will connect (based on LED lights. But the app shows the base station is offline and i can't access any cameras.
garyw342,
If you performed a factory reset without removing the base station from your Arlo account first, this could be the issue. Navigate to Settings > My Devices > select your base station > Remove Device. After it has been removed, log back in to your Arlo account and click "Add Device", select base station and follow the on screen prompts.
