Arlo Base Station Goes To Only 1 Green Light - Fails Setup
  • 8 Replies
  • 5155 Views
  • 4 Likes
WoodenIgloo63
Hello,
My Base station stopped working suddenly.  It has one green light on it.  I tried resetting it and unplugging and plugging it back in, no dice.
Fails setup.
What is Netgears refund process (policy) on something I bought on Feb 8th, 2016 ?
WoodenIgloo63 wrote:
OK so far:
1)  Button #1 blinking (power)
2)  Button #2 Blinking ( ?? )
3)  Button #5 Blinking (show a little usb connection icon)
Unsure where to go from here.  Tried resynching one of the cameras, but no dice.
Any other ideas?
Yes... contact Netgear... sounds possible defect.
LED #1 is power and should ALWAYS be STEADY on even if nothing else works.
8 REPLIES 8
Which of the THREE lights are still on ?
WoodenIgloo63
The far left one.
Arlo has been up and running for me fine, until something went wrong.  Now, Like I said, It fails the setup and I only have the one green light.
Thanks for your help so far!
Left is the power light... no internet, no cameras
You said reset...but did you do a full factory reset?
Hold in the reset button ( with paperclip ) for about 10 secs till all the front LEDs flash
WoodenIgloo63
OK did a full factory reset!  Will try and go from there!  Thanks again Tom
WoodenIgloo63
OK so far:
Any other ideas?
#2 is the Internet LED and should be steady.  #5 should never be on - it implies that you held the sync button on the base too long when trying to sync the cameras.  Power cycle the base and press the sync button for only 1-2 seconds.  Syncing should work fine then if all is well.
OK so far:
Any other ideas?
WoodenIgloo63
Thank you Tom, I contacted Netgear Tech Support and I'm pretty sure they'll make things right!
Woodenigloo
