Arlo App keeps Logging Out In Back End Of Andriod Phone
Hi
I use an android phone (Oppo), the issue is if I open Arlo app and just quit to use another App (the Arlo app will be running at back end), it is ok for a few minutes, however after maybe 1 or 2 hours when I click into Arlo app, it logged me out automatically and I need to log in again.
the issue is when it log out, it won't send me push notification if there is a motion deteted.
How do I solve above issues? Does anyone have same issue? I have already disabled battery saving on Arlo app and all other settings will disable Arlo from running at back end.
ArloSydney,
Do you have the latest version of the Arlo Mobile App installed on your phone? I have attached a link with the Arlo Firmware release notes here - Arlo Firmwre release Notes
Hi
I always update the App in my phone automatically, so it should have latest version.
ArloSydney,
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
