Arlo released 2 updates within the last 48 hours or so for the iPhone. Each time an update was installed, it created duplicate entries of all my devices. I tried just removing the duplicated entries but that renders the entire setup useless. I had to twice, completley uninstall all my devices, settings and app then reinstall and start from scratch. Will this be an ongoing issue to look forward to each time there is an update? Also, I have opened a ticket with support several days ago when this first happened. So far i have not received any response.
dturner26,
This should not be an ongoing problem in the future. The engineering team is currently investigating the cause of this issue.
Did the steps you took above resolve the problem or do you still see duplicates?
I have the same issue. My camera's are all duplicated on the iphone app. Even if I delete all the cameras they still show on the main 'devices' screen. Note: it seems to work fine via the ipad....just the iphone is a problem for me.
All the duplicate and obviously non working camera views make it nearly impossible to use the iphone app. Are there any work arounds until this is fixed ?
This issue is still being investigated by the engineering team. Please do not attempt to remove the duplicate cameras as this does not resolve the issue. Some users have reported having success by uninstalling the Arlo mobile app and downloading a fresh version from the app store. I will post an update when I have more information.
We apologize for any inconvenience this may cause and thank you for your patience,
Re-installing the app on the iPhone corrected the duplicate cameras. Thank you.
