Arlo Android Application Not showing "Okay Got It" button
  • 1 Reply
  • 1147 Views
Yoga_Prayoga
Hello,
I have an issue with the app compatibility, the display on Android App won't showing the "Okay Got It" button.
Attached 2 Picture for the Difference. On the Left side, we using samsung phone, and the right side we using Blackview BV6000s.
Please help as we are using the Blackview BV6000s as our operations.
Thank you.
Contact support using the link at the bottom here. It appears to be a display/resolution issue between the app and phone. You could also try holding the phone in landscape mode to see if you can scroll to the button.
