RMA Process problem
  • 2 Replies
  • 2500 Views
GrumpyGramps
I've been unable to raise an RMA, as requested by technical support. I get as far as submitting my details but after that nothing. All  required details have been filled in.
I have searched the community and there seems to be a fundemental issue with the overall process, which doesn't reflect well on Arlo. If I'm unable to resolve the issue soon then I shall return the order to the supplier - Amazon UK.
Any help in completing this process would be very much appreciated.
GrumpyGramps
Hi ShayneS,
Thank you for your reply. I have now managed to contact Arlo Support but only first having to go through Amazon UK technical support.
I've now obtained the RMA return address.
Regards
Jonathan
ShayneS
Hi @GrumpyGramps
I have escalated this issue for you and customer support will be contacting you as soon as possible.
GrumpyGramps
Hi ShayneS,
Regards
Jonathan
