App version6.6.0
Hello,
I am implementing Routines and i while it seems un-neccasarily complicated vs the old version i think i follow most of it.
The issue i have is:
if i set a schedule to switch on my cameras at sunset vis ARM HOME - All good
If i then for example leave the house after Sunset it switches to ARM AWAY - All good.
If i then return it switches to STANDBY but then doesn't understand there was a previous schedule set to ARM HOME at sunset.....
This seems to be quite a big flaw..... Unless I am mis-interpreting how to set it up somehow.
Thx for any thoughts / responses.
Correct, this is a flaw in the design. You can choose what mode to switch to when you return, but the system will not immediately resume the schedule. It should be switching to the correct mode at the next schedule time (likely Sunset the next day in your case).
I think that when they restore custom modes you will be able to do what you want.
