Why can I not get to my account page? I try to access the application and it just flickers over and over. Any suggestions would be appreciated.
Uninstall and reinstall. There was a bad update released the other day that has been pulled. The reinstall will get you a working version. There are other threads here about the same thing.
Use the task manager to close the app. Then start the app again. You might have to do this twice
I used the task manager to close the app numerous times but to no avail. Still can't access my account page. Thanks for the suggestion any way.
Reinstalling fixed the problem. Thanks 😊
