Allow GeoFencing as a choice under Schedule
  • 1 Reply
  • 1913 Views
  • 1 In Conversation
ERoi50
I would like to be able to nest modes UNDER schedule. Specifically, GeoFencing. I want the system armed when I go to bed, then go into GeoFencing when I wake up, so it adjusts from Armed to Disarmed if I'm home or not.
Pro3
ERoi50
Nevermind, I figured out how to set this up. Here's how I did it:
  1. Created a custom mode I called "At Home" for how I wanted our cameras to work when I'm at home.
  2. Edited "Schedule Mode" for a *24 hour plan. Overnight I have it turning to "Armed" mode. During the day, I point the Schedule to my custom mode, "At Home".  *To set a 24 hour plan in Schedule, you have to create at least 3 different sections. Mine was 5:30a-10p (day) 11p-11:59p, 12a-5:29a
  3. Under GeoFencing:  Go to "Select Mode" section at the bottom. Away Mode is set to "Armed" and Home Mode is set to "Schedule".
Boom! Now my system never has to be set! Its automatically armed at night and when I'm away from home. Arlo, is there a KB on this? There should be! Use this! In fact, there should be a section for software support.
Pro3
ERoi50
Pro3
