Hi there,
I installed my 5 camera system 2 days ago and everything has been working great. I got the "Geofence needs an internet connection" error on my Android phone, so I went to check the system and nothing is listed in my Device list. Just an "Add Device" button. I have some items in my Library from earlier tonight, so I know the system was working.
I've cycled the power a few times to no avail.
Any suggestions on getting them back? Or do I need to do the whole setup again?
TIA!
Mike
Engineering has identified and deployed a fix to resolve this issue. No updates or changes need to be made to receive the resolution. Please let me know if you continue experiencing this behavior.
Thanks Steve. Any idea why this happened?
Did the Factory reset and had to re-sync all cameras. Everything is up and running again. Hope I don't have to keep doing this... Hope it stays up this time.
Thanks Steve!
I don't sorry. But glad to hear you're up and running again. Hopefully it's just a one off glitch
Just got home and checked my system.... All devices are gone AGAIN! I had GeoFence on... maybe that is doing something.
Any Help from NetGear would be appreciated!
I know when I start my Android app, it initially shows no devices and only the "Add camera" is visible, but about 3 seconds later, my devices list shows the cameras with the preview window showing the last recording. Perhaps it's just taking a longer time to move forwards? Or maybe it's getting stuck at this point?
Do you also have no devices listed if you log in through the web access?
It shows no devices no matter where I log into... Phone or Web. I also called Customer Service. Got the same story. Engineers are looking into it. They had me do another Base Station Reset and I'm suppose to see if it fails again. Then call them back if it does. I only sync'd 1 camera this time... kind of a pain to unmount all 5 cameras to re-sync them.
Might just return mine to Amazon.
Same issue here. Bought mine two days ago and this is the second time that it has happend to me. If this is a regular occurance the system is useless. I cant keep doing a factory reset then climb on th roof to take down all the cameras and sync them again. From the number of complaints im reading it seems that the problem is on Arlos end. Seriously considering sending back for a refund too. Wish I had read the forums first before shelling out $500.00. Arlo needs to rectify this ASAP.
Are you viewing from the mobile app (iOS, Android)? Do you see the same behavior when viewing from a different device?
I've escalated this topic for further investigation. Please let me know if you continue to experience this behavior.
Thanks James. I did a factory reset and everything came back online. Lasted for 3 days and has happened once again.
I had added only 1 camera back and it ran well for a day. So I then added the other 4 back on Saturday. Logged in this morning (Monday) and all devices are gone again. I did not use GeoFence this time as I though that might be the issue. It apparently isn't.... About to return my whole system. This is unacceptable.
Tater7786,
I apologize for any miscommunication. There was no firmware update or any updates that you would have needed to complete to receive the fix. You would have had to add your system back to your account and resync cameras after the fix was implemented though. Did you experience this issue again after I posted that the fix was released?
