After the batteries have died my camera won't sync
  • 1 Reply
  • 5474 Views
TRUDE-Hamburg
After the batteries have died my camera won't sync with the base station again. If I push the sinc button on the camera the LED will start flashing slowly not rapidly as it is supposed to when starting the sinc. Have removed batteries several times and started over. Always does the same thing .... can anybody help? Thks Holger
steve_t
Master Master
You shouldn't even need to resync when you change batteries. Just closing the battery compartment door should have it reconnect. Failing that, remove the camera from your device list. Hit the sync button on the base station and the camera light will blink green. Hit the sync button on your camera and it will blink blue. If it doesn't connect then, go through the process again but with your main router's wifi turned off but ethernet still providing the base station with internet
Good luck
