After the batteries have died my camera won't sync with the base station again. If I push the sinc button on the camera the LED will start flashing slowly not rapidly as it is supposed to when starting the sinc. Have removed batteries several times and started over. Always does the same thing .... can anybody help? Thks Holger
You shouldn't even need to resync when you change batteries. Just closing the battery compartment door should have it reconnect. Failing that, remove the camera from your device list. Hit the sync button on the base station and the camera light will blink green. Hit the sync button on your camera and it will blink blue. If it doesn't connect then, go through the process again but with your main router's wifi turned off but ethernet still providing the base station with internet
Good luck
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
