After Naming Base Station During Install Process It Says No Devices Found
- 2
After i name the base station on install process it says no devices found. Am i missing something? I tries the rest and unplugging everything but still the same. Everything is greens besides last LED
I tried this already yesterday but just to be sure I followed your instructions step by step.
On the base, after the reset, 2 lights are green. The third starts flashing green after I push the sync button. On the camera, the light starts blinking blue after I push the camera sync button. This continues for +- 2min and then the camera light blinks amber for 10 sec and then turns off. On the base the third light turns off.
No camera detected! Very disapointing for what I thought was the best security camera solution on the market :-(.
Assuming you didn't hold the base sync button for 2 seconds, it appears that you have a faulty system. Swap at the store if you can or open a case with support here:
Since I had a hard time accepting that the problem was caused by a faulty system, I decided to do my own analysis.
It took me about an hour to figure out that the only reasonable explanation was an error at the level of the network.
So I switched off my wifi-router (Netgear Orbi) and connected the Arlo base directly to my cable router, I reset the Arlo base station and deleted all devices from the system, I then restarted from scratch and connected all 4 camera's, switched on the wifi-router and - voila - everything worked.
I am having the same issue I have called for support multiple times. all I get back is that this is a known problem. So now I have a 400$ system that has been sitting on my counter since christmas. This is pathetic. I heard ARLO was a great system but this has been an absolute crap show.
Are you serious? I am currently on hold with Arlo support.
after reset, power and internet lights are glowing green and cameras light is orange. it is directly showing add new device and when I tried to add base station/cameras, it is showing now divices found.
I had the same problem and decided that it had to be related to the wifi netwerk.
So I changed the WIFI channel on my WIFI router, did a reset of the Arlo and since then everything works like a charm.
Having same issue but with Xfinty, base shows all green lights, cameras sync, but no devices found,
has anyone else have probelms setting up thru Xfinty?
Have you tried to reboot the base station & check again? At what do you receive the eno devices found message?
Return to store and looking fir a different system
Any Solution ? I am same issue I renamed my base station and cameras were not synced and i deleted base station and tried to add device now It Says No Devices Found.
Please advice.
Hi @Branjay
- 2
