  • 8 Replies
  • 5545 Views
KYBOB
Camera run time not responding to adjustments
8 REPLIES 8
steve_t
Master Master
Are you ensuring you click SAVE? It may be on the previous page or you might have to scroll down to find it depending on which platform and device you're on
KYBOB
Yes, and thank you for responding.
It is in Armed mode
Camera selected, selected record time slider from 10 sec to 25 and then save.
But still only recorded for 10 sec.
Also tried rebooting base unit.
KYBOB
The unit is the VMS3330
Streak2
Master Master
If you are using the app to do this then try the web interface at arlo.netgear.com
mode - edit camera - motion is detected - drag the slider- back - and then save.
KYBOB
Thank you , I will try that next. And yes I’m trying to adjust from the App.
Another question , is it possible to have two cameras record from one trigger camera?
steve_t
Master Master
Yes. You have to make a custom recording mode. Then make two rules where
Camera A motion causes Camera A to record
Camera B motion causes Camera A to record
You may also want Camera B to cause Camera B to record and Camera A to cause Camera B to record
I have these 4 rules on 2 cameras  near my front door
KYBOB
Thank you for the info.
I may play with custom settings after I get the recording times adjusted.
Much to learn
KYBOB
Ok, here’s the follow up. After several attempts to adjust the record time, ( going through the PC made no difference) , I pulled the cameras, took batteries out, unplugged Base unit, cleared everything and started over. It is responding now and have set the cameras to 20 to 30 seconds each.
Not sure where the glitch was, but it is fine now.
I do have other questions, but for now, I’m experimenting with camera positions and sensitivity.
Thank you for the guidance.
KYBOB
