  • 1 Reply
  • 1658 Views
WeeBob
Hi I've got an extensive property with good WiFi coverage (7 Google mesh ) and 2 Arlo Pro 2 cameras. I want to add 2 or 3 additional cameras in areas that are out of range of the base station (but not the nearest WiFi mesh router). If I install a new Arlo base station to the nearest mesh router and pair the cameras to that will that a) work will - or does it need to be connected to the main router? and b) it link to the same account or will I end up with 2 accounts?
Yes.  FWIW, I have two base stations, and one is connected via ethernet to one of my Orbi satellites.
@WeeBob wrote:
If I install a new Arlo base station to the nearest mesh router and pair the cameras to that will  b) it link to the same account or will I end up with 2 accounts?
Yes, you can add the new base and cameras to the same account.
Though you didn't ask - the newer cameras (Ultra, Pro 3/Pro 4, Essential) all require a paid subscription to get any cloud storage.  The older cameras (Pro, Pro 2) have 7 day cloud storage - but there is a limit to 5 cameras per account.  If you are planning more than 5 of these cameras, you could set up two accounts, and use "friend" access to share them, so they can all be accessed from one account.
