Purchased extra camera and it won't Sync. Blue light on camera just keeps blinking blue. All other cameras work fine, base station appears to be fine and green sync light blinks but the camera never stops blinking. Removed batteries several times.
You are talking the Q camera...? This posted in the Q Plus section...
if it doesn't sync, RESET the camera by holding in the reset for 10 secs till the front led flashes amber
Attempt sync process again ( for setup you need the SSID of your router and the password to log into the router like other wifi devices )
If you mean Arlo or Arlo PRO, open battery door remove and replace batteries/pack... QUICK push on the base sync button ,don't hold
Sorry not Q - Arlo wire frer
