Adding a second base station
  • 5 Replies
  • 24578 Views
  • 2 Likes
  • 5 In Conversation
BeanoC
I need to add a second base station, as well as additional cameras, to my Arlo system. (I have the Elite Plan subscription). Can they only be used as range extenders, or can I place the second base in a different phyisical office? I was thinking I would just buy another "startup" kit, with the base station and 2 cameras.
Can I do that and use it with the same account, off premises, or does it have to be within range of the first base station?
5 REPLIES 5
dtorres30
Yes, your second (and third!) base station can be in any location and does not have to be within range of the first. Across town, in another state, etc. Totally acceptable.
Just keep in mind when activating the second base station, the device you use to do that will need to be on the same network as that base station. (In other words, you can't set up the other base station in Florida, then go back home to Colorado and activate the FL base station remotely).
Heritage
1st=connect station to same network as first  (You must have it connected to the same Network to configure)
1.5=log into your arlo account
2nd=Select "Settings" bottom of window
3rd=Under "Account Settings" select "Subscription"
4th=Upgrade account to elite (about $150 fill out order form)
5th=Under "Base Stations" select "Add a Base Station"
Your almost done rename the base station so you can remeber it and save
6th=unplug it and take it to your second house (Not the same network)
Its mad easy
JLW207
I boughht a 2nd base station and extra camera for a 2nd home.
I already have the 1st on my iphone.
I am unable to get the 2nd base station on the same iphone.
What do I do?
Did you
1) buy a higher grade plan that supports more than one base?
2) if not, then you must be using a different email and two different accounts without auto log-in
Heritage
And set it up on the same network, then once configured take to second home. If your cheap create a second account or if lazy upgrade to elite then confiure it
