This is the message I am getting after syncing a new camera, upping the total in my house to 2.
We see you've synced a new camera.
Your service plan supports 5 cameras.
and start viewing your new camera right away.
I have reset, unplugged, and resynced and still get the same message. Any ideas?
I'm getting the same problem, having added a camera to a system that had 3 cameras previously (4 total now). Anyone know what's going on?
Same problem here. Arlo is a total bag of hurt.
Same thing here. I deactivated the base station,thinking I could reactivate it and ev anerything would work they way it should. I only have 4 cameras. In settings, it shows 5 cameras and no base station supported. There is no way to reactivate the base station. I have done a factory reset to no avail. The base station is online and communicating with Arlonetgear servers because the green lights are lit and solid green on the BS. When I log in, I get a message describing how to sync cameras. No access to camera settings, or mode. Would sure love for this to get resolve since I have no security system at the moment.
I have the same problem... getting frustrated... we had 4 added a 5th and can't get it to work it wants us to upgrade!
I am having the same issue, added a 3rd camera and it was sync to the base station but my camera screen is blocked with the same message, I do not need to upgrade only have 3 cameras on a five camera system.
ArcticMonkey wrote:This is the message I am getting after syncing a new camera, upping the total in my house to 2.
UPGRADE PLAN >and start viewing your new camera right away.
I have been on the phone on hold for over 35 minutes, if I hear anything I will let everyone know. Also read on another thread that their engineers are aware of the issue.
fdewy wrote:
Having the same issue. On the phone waiting for support. Will post here with what they tell me.
Just got off the phone with support team, they are having software issue and the engineering resolution team is looking into the issue.
Judging from the other posts on this community site, I think we all probably should get used to this sort of thing. Looks like they took a team that was used to building web-UI's for off-brand routers and let them try their hand at a mobile app and associated backend infrastructure. If they don't have systems in place to avoid pushing bugs like this into production, I also wouldn't expect much in the way of security, so watch where you point 'em.
Now, I have even more problems. i followed the instructions to re-install the system. I now have three base staions showing, and none of them will connect to the interne. I only have four cameras and one base station. I hope this issue is resolved soon. Up until now, the system has worked very well. But since last night and today, I am without a security system.
support says it is an engineering issue they are working on mine is doing same thing could not give me a time frame as to when it would be repaired
Support says engineering issue working on repairing mine doing same thing
i also just added/synced a new camera and the web app shows the same as in the original post in this thread. On the "Cameras" tab in the Android phone app, neither my original camera nor the new one is listed, only the line "See another camera here" and the link to purchase new cameras. If I go to the "Mode" tab, it shows the base station ID and "Getting status..." but never does anything else.
NETGEAR Support Team
Received an email a couple of hours ago. Engineers anticipate having the software issue resolved within the next 12 hours. Hope this helps.
Good afternoon Arlo Community,
I am reaching out to you today to inquire if the issue with syncing a new camera has been resolved. We believe the issue has been fixed but would greatly appreciate feedback from the community to confirm our findings are correct.
@billstokes - I recommend contacting support to determine why your cameras are still showing offline. if you haven't done so already you may try rebooting the base station and/or try to re-sync your cameras. We would greatly appreciate your feedback as well in the event other community members are facing the same issue.
Best Wishes!
Christine
NETGEAR Community
____
Please click
KUDOS or REPLY if you found this helpful.
I reset my base station and reinstalled the system using a different email address and re-synced the cameras. Everything is working fine, now with my system.
Good evening jmtucker27,
I am glad to hear your system is now working as expected and providing your valuable feedback!
Kind Regards,
Christine
____
Please click
