Adapter for Arlo VMB5000
Original adapter for Arlo VMB5000 has this 100-240V 50-60Hz 0.6A 12V 1.5A Can I use this: Netgear 200-240V 50-60Hz 0.5A 12v 1.5A. The difference is these two numbers 0.6A and 0.5A does this have any significance?
It was purchased in the USA to be used in Sweden which has 240v.
This is the amperage drawn from the mains - slightly lower the original. Output power (60w) is the same. If the polarity matches and the barrel connector fits it shoulld work.
Thank you very much, I'll try that and see how it goes.
