  • 46 Replies
  • 5121 Views
KachinaShadow
Prodigy
Prodigy
I have always set activity zones via the web portal just because they can be more accurately set using the larger PC screen as opposed to the smaller phone screen. Now, on the web portal, I am able to see and adjust activity zones on all of my cameras except the two Pro 3's which, when I select activity zones, the screen times out and is never able to show those activity zones.
The whole reason I found this is that some of my activity zones (not just the Pro 3's) had actually shifted considerably, as if the field of view had changed...it had not. So, just more unexplained changes that add to the frustration of using this system.
46 REPLIES 46
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
When are they going to install this "custom build for these Pro 3's", which never seems to come?
Every day I climb the ladder and pull/reinstall the battery, hoping that both Pro 3's don't go offline at once, in the middle of the night, and miss this "custom build". So far, they only seem to have one or the other go offline but every morning I check the one that remained online, hoping to see the "custom build" that never comes.
Needless to say, this is getting old!
KachinaShadow
Prodigy
Prodigy
@BrookeN
In yesterday's post, regarding one of the Pro 3's that went offline the night before, I reflected on having to once again climb the ladder to remove/insert the battery. Well, I didn't have time to do that yesterday but last night, while watching TV, I noticed the blue lights flash and that Pro 3 came back online by itself after almost 24 hours of being offline.
What were you able to find out anything about this "custom build" that never came?
KachinaShadow
Prodigy
Prodigy
Well, the other Pro 3 is offline this morning 😠
I'm getting really tired of dragging the ladder into the house almost every day to make sure both Pro 3's stay online while waiting for some new build or fix that never comes. Since I found that the other Pro 3 came online by itself yesterday, I'm just going to wait and see what this one does.
KachinaShadow
Prodigy
Prodigy
@BrookeN
On 06/05 you wrote "@KachinaShadow we have a custom build for these Pro 3 let me reach out and have your devices moved over" followed by "@KachinaShadow I had these migrated over, you should see it as resolved by tomorrow".
Any idea on when this "custom build" is going to be installed since it's been 2 weeks since they were supposed to do that?
KachinaShadow
Prodigy
Prodigy
@BrookeN
Looks like the Pro 3's have been moved over and all is well 👌👍
KachinaShadow
Prodigy
Prodigy
@BrookeN
I guess I spoke too soon...I still have the Pro 3's going offline at random so it's back up the ladder to remove and reinsert the battery ☹️
KachinaShadow
Prodigy
Prodigy
@BrookeN
The other Pro 3 is offline this morning.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Another Pro 3 update...after being offline for a day, my other Pro 3 seems to have brought itself back to life 🤔
Between the two Pro 3's they seem to alternate at being offline every few days but usually I have to remove and reinsert the battery to get them to come back to life. This is only the 2nd time that either of them has come back online on its own.
BrookeN
I have let the team know about the Pro 3, I do not have any updates as of yet.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Just an FYI for the team...
In the last three days both of my Pro 3's have gone offline...the one three days ago, actually came back online after a day and a half and the other was offline this morning when I looked at the system...we'll see if it comes back online on its own in a day or two.
Note that these two Pro 3's are only included in the "arm away" routine, along with one Pro 5 (which has never gone offline), so these three cameras are idle most of the time and arm away hasn't been activated for a couple of weeks.
KachinaShadow
Prodigy
Prodigy
@BrookeN
This probably has nothing to do with anything but in my last post I noted that I was going to just leave the Pro 3, which went offline four days ago, alone and see when or if it came back online without my dragging the ladder in and doing the remove/reinsert the battery routine.
As you know, the whole time it's offline it's trying to reconnect and is using up battery, so this morning when I received an email the battery had reached 15% and needed to be charged, at around that same time that camera came back online, like freakin' magic 😮...of course that doesn't help much since now I have to drag the ladder inside to pull the battery and charge it 🙄
BrookeN
I did let them know there is a few users seeing the Pro 3 going offline again. I don't have an update as of yet, but I will reach out soon.
BrookeN
@KachinaShadow have you seen any improvements with the Pro 3's?
KachinaShadow
Prodigy
Prodigy
@BrookeN
It's been a couple of weeks since they've gone offline and they seem to be working just fine so I'd say that the problem has been solved 👍
BrookeN
Thank you for letting me know.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Thought this was finally solved but yesterday morning one of my two Pro 3's was once again offline and restarting the Base (VMB5000) didn't help so I thought I'd give it a day and see if it would come back on it's own (like a few times in the past).
This morning I found that both of my Pro 3's were offline so I tried restarting the Base again and the second Pro 3 came back online but the one that went offline yesterday morning remained offline.
When I get a chance, I'll get the ladder out and remove & reinsert the battery 🙄
KachinaShadow
Prodigy
Prodigy
One of the Pro 3's is offline AGAIN this morning 😠...I'm just going to keep noting this until it's fixed 🙄
KachinaShadow
Prodigy
Prodigy
@BrookeN
The Pro 3 that was offline all day yesterday is back online this morning (by itself, I did nothing) but my other Pro 3 went offline this morning 🤔
KachinaShadow
Prodigy
Prodigy
@BrookeN
Yesterday morning I decided to climb the ladder to remove/reinsert the battery on the Pro 3 that had gone offline and, since both Pro 3's were at around 60% battery, I thought I'd charge the batteries.
In less than 7 hours after inserting the fully charged batteries, the other Pro 3 went offline 🤔 and if it doesn't come back online by tomorrow morning it's back up the ladder ☹️
KachinaShadow
Prodigy
Prodigy
@BrookeN
Quick note...the only cameras that didn't respond to the "fix" shown in the thread...  Solved: Re: Live Stream is currently in use by another dev... - Page 2 - Arlo Community  ...are my two problem Pro 3's which seem to have become almost useless when the issue, that this thread was initially about, began...go figure 🤔
Almost like they have some kind of electronic device "immune deficiency" so that whatever comes around...they catch it 😉 🙂
KachinaShadow
Prodigy
Prodigy
Yet another Pro 3 went offline tomight.
KachinaShadow
Prodigy
Prodigy
@BrookeN
This morning both Pro 3's are offline 🙄
